Change an old web maps measurement default from Metric to US Standard
1061
08-06-2024 09:41 AM
JamesBurton1
I've got an old web map that seems to be stuck with metric as it's default for measurements. Our organization default is US Standard. New maps use the imperial measurements, but I'm trying to avoid having to remake this map since it has a lot of configurations set up. I've looked at the JSON in ArcGIS Assistant, but I don't see anywhere to change it there. Any suggestions?
JamesBurton1
My solution was to use the measure tool from Experience Builder, as opposed to the measure tool from the map. So now I can choose the default values but it is a different element, so it takes a little more configuration to set up as a widget with the benefit of more customization of the units and placement.
JamesBurton1
