Cannot Add Service Through Add Item In ArcGIS Online
3372
10-12-2012 12:16 PM
by Anonymous User
Not applicable
Original User: alattin
I am having problems adding the REST endpoint in ArcGIS Online through the "Add Item" on the web. The error returned is "Service does not exist or is inaccessible." However, this should not be the case as the map service can be accessed by the public, and the url is correct. ArcGIS Online just fails to even access it. Would the problem stem from using ArcServer 9.3.1 with ArcGIS Online, possibly? Any help would be appreciated on the matter. Thanks.
by Anonymous User
Not applicable
Original User: j.quinn
Can you provide the service url?
by Anonymous User
Not applicable
Sure, the url that I have been using for testing is: http://maps.co.benton.ar.us/ArcGIS/rest/services/PublicBaseMap/MapServer. I have also tried Esri's sample rest services, but some will work other don't.
JonathanQuinn
Esri Notable Contributor
What browser are you using?  I can upload it fine using Firefox.  You've tried both adding it to your My Content section and directly to a map?
by Anonymous User
Not applicable
Got it with firefox. I've tried Chrome, ie 8, and 9. They didn't work. Thank you for the temporary solution.
