Can you add a global ID field to an AGOL hosted feature service?
9837
01-30-2018 03:35 PM
MStayner
I have several hosted feature services already published to ArcGIS Online. I know I can download them, add a global ID in Arc Map then republish. Is it possible to add a global ID directly to a hosted feature service?
MJBiazar
Enabling sync for the hosted feature layer will add a GlobalID field to the hosted feature layer.
shan_sarkar
Global ID is a database table property and can be enabled in ArcGIS Desktop/ArcGIS Pro (Add Global IDs—Help | ArcGIS Desktop ). Once the fields have been added you need overwrite the hosted service.
I hope this helps!
~Shan
~Shan
MJBiazar
Amanda__Huber
MVP Regular Contributor
Hi @MJBiazar
Are you referring to this Sync setting? I'm not seeing GlobalID information in the documentation.
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-editing-hfl.htm#:~:text=Enable%20editing%...
MJBiazar
Hi @Amanda__Huber yes, if your layer is published without global id field, enabling sync in the feature layer settings in ArcGIS Online creates global id field in all layers in your feature layer.
You are correct! This is not mentioned on our documentation and I encourage you to submit a documentation feedback for this.
Thank you
Amanda__Huber
Great! Thank you, I just submitted after testing.
Best,
Amanda Huber
