Can there be a send occurrence of spike_p2p in the same survey 123 app for a different point to point measurment
344
08-07-2019 07:39 AM
JeffCarney
I have created a survey 123 connect app and integrated with Spike. There is a requirement to obtain a horizontal distance between two points using the point to point method. There is a requirement to collect as a point to point measure a second horizontal and vertical distance for a different purpose. Can "spike_p2p" be used as the image name a second time or does it need to be "spike_p2p1" or p2p_1" or something similar to differentiate the images?
JamesTedrick
Esri Esteemed Contributor
Hi Jeff,
If you need to create multiple point to point measurements, you should give each a unique value in the name field to be able to distinguish which image is associated with a given capture.
