Can the Spy Glass be enlarged?
3892
06-28-2015 07:30 PM
jaredpilbeam
Hello,
I've created a spyglass map (http://arcg.is/1Lx1tpP) and wonder whether the spyglass can be made bigger so as to see a larger area underneath?
Thanks for any help,
-Jared
ChrisSmith7
Honored Contributor
I could be wrong, but briefly looking into the JS, it seems that it's not possible (at least without reworking the API yourself). Further confirming this is the sprite icon jpg used buy the feature:
http://jared.maps.arcgis.com/apps/StorytellingSwipe/resources/icons/sprite-icons.png
RickeyFight
MVP Regular Contributor
Jared,
What if you did something like this?
Layer Swipe But with your layer.
StanMcShinsky
I did some good looking and found that it is in the api. I tried for a few minutes to adjust your map on my local server and could not get it working with changes. Sorry.
-Stan
jaredpilbeam
Thank you all for looking into it. If it's not possible to enlarge it, I guess i'll have to go the swipe map route.
LarryStout
Jared,
I've just started a new job and have been offline for a few days.  Does the Swipe Plus widget on this page do what you are looking for?
Hamilton County Map Viewer
Larry
