Can't update service definition
1457
08-12-2021 08:44 AM
JamesMcClellan
I'm trying to update a service definition as per these instructions:
https://support.esri.com/en/technical-article/000012383
This is the service that I need to update.  I need to increase the maxRecordCount:
https://services6.arcgis.com/pkAymxjI3epp4VoG/ArcGIS/rest/services/WARDAT_Entities/FeatureServer
However when I get to the part that says:
  1. In the browser's address bar, insert 'admin' between 'rest' and 'services' in the URL like the one displayed below:
It takes me to a page that just says Token Required
What am I doing wrong?
JakeSkinner
Esri Esteemed Contributor
Hi @JamesMcClellan ,
Try the following:
1.  Log into ArcGIS Online
2.  Go to the item details of the service you wish to update
3.  Click View at the bottom of the page:
This should add the URL with a token to a new tab.
5.  Add the admin portion into the URL.
JakeSkinner
Try the following:
JamesMcClellan
Thanks! That did the trick!
