Can't create multiple hosted feature layers from single google sheet with multiple tabs
1643
03-25-2022 09:23 AM
StephanieIngraldi
I am generating hosted feature layers from a google spreadsheet with multiple tabs. A month ago, I had no problem uploading each tab as its own layer. Now I'm trying to re-upload the layers, but the drop-down menu with my tabs in gone and I get this error message: “A file named "[my spreadsheet name]" already exists in this folder. Please rename the file and try again.”
I've done some testing and I know the following are not causing the issue:
  • New tabs to the spreadsheet added/renamed/moved since I uploaded my first feature layer. I created a new test spreadsheet with multiple tabs and got the same error message when I tried to create my second feature layer.
  • Google form linkage
  • Column name duplicates in a single tab
I've tried doing this with multiple other spreadsheets with different properties and get the same error message any time I try to add the second feature layer, which leads me to think this may be a bug.
ABishop
MVP Alum
Hello Stephanie,
Try updating the current hosted feature layer instead of trying to republish over the old one.
Amanda Bishop, GISP
StephanieIngraldi
My reason for re-uploading instead of updating the layers is that I've since changed the columns in the spreadsheet (deleted/added new ones). When I try updating I get the 'Adding item...' buffering page but it never goes away and the layer never updates. I don't know if this is because of the column mismatch or the existing name issue.
ABishop
MVP Alum
Yes, absolutely the change of the table schema would definitely make it impossible to update.
Amanda Bishop, GISP
