I have created a web map via sharing from ArcGIS Pro.
When viewing the online map, I can not zoom in, only out. Scale min is like 1:8000
Help, I must be brain-dead
Hi @GarryPetrie,
Some more information would help with troubleshooting.
Any chance you are using a tiled basemap that doesn't have any tiles at a scale larger than 1:8000?
R_
The buttons are there. I created the layers via hillshade tool. I set the property to be viewable at all scale and that is the case on the desktop. Not so much in the ported webmap.
Not about the basemap. The TIF images created via hillshade and have infinite zoom on the desktop. Not so much on the ported webmap.
which makes sense. Desktop will have infinite zoom, however, Web map will only have the zoom levels allowed with the basemap. If you can't zoom in past 1:8000 (rather than the image just disappearing when zoomed in past that) I suspect the basemap you are using doesn't have tiles at zoom larger than 1:8000 (though, that doesn't sound quite right for a basemap).
Can you share the web map (or basemap) that you are using?
I can zoom well past 1:8000 and still see the lidar images rendered. I would say the drop out is around 1:200. The base map is WorldImagery.
https://troutlakecaves.maps.arcgis.com/apps/mapviewer/index.html?webmap=36801a13091e452390efd08e33db753c
Looks like a sub-layer in there (the Tile Layer itself I guess) still has a visibility range set:
Even if you change the visibility in the map viewer, the service may still be honoring the Tile Layer's settings from its creation (publishing). Can you show the method/settings you used to create/publish the Tile Layer?If I look at the REST service information for this Tile Layer, it shows a scale limit that will affect everything within it:https://tiles.arcgis.com/tiles/iiEO9Ir7FRiWwFTn/arcgis/rest/services/Saddle_Butte_WTL1/MapServer
EDIT: woops @RhettZufelt beat me to it 😆 ... and I was looking at the wrong map service, but it appears they are both published with the same settings.
Changing this has no effect
Ok just for a real quick test, it looks like when publishing a web layer and choosing 'Tile' you are presented with some Configuration options. If I pick auto-suggest, it seems to present a maximum LOD of 18 in my case. However, ArcGIS tiling scheme should let you go to level 23 (1:71).
If you need an even higher LOD, or a different projection, you'll have to create your own Tiling Scheme which is not incredibly hard but it's a separate process. I had to do that, for example, for a custom basemap for some of my users to be able to zoom into features that are relatively close together, in order to be able to distinguish the features and their labels where necessary.
I am trying this now. What is the difference between Share WebMap and Share WebLayer? I use WebMap before. I tool also complains about the large number of tiles to create. I had previously assumed the tiles were created dynamically by the server, not by the user creating them before hand.
I don't think this is the correct approach. It appears to have crashed both ArcGIS Pro and Chrome on the desktop.
This maybe different in your version of Pro (i'm on 3.2.5) so take this for what it's worth.
Sharing a map as a web map will basically make your whole map layer contents into a hosted feature layer, or hosted tile layer, depending on if you choose the configuration for exploratory/editible or the visualization option.
I think if your map layers contain a raster image (e.g. your hillshade) then it doesn't give you the option and instead it will default to creating a Tile Layer.
Although you can drill down and configure some properties of the Tile Layer that it creates, it seems it locks you into using the Tiling Scheme of the current basemap of the map you're publishing from. Maybe that's fine, as long as you get to choose the LOD you need:
Alternatively sharing certain groups (or individual) layers as a Web Layer means you potentially have more control; you can have different layers that you publish from different ArcGIS Pro maps, to become separate hosted feature layers or hosted tile layers items in AGOL, and then you can choose what you want to add to a web map in AGOL, rather than having them all bundled together. I would generally highly recommend this if you tend to have different versions of web maps or need to republish map layers for various reasons as you're developing a map/app product. You won't be throwing the baby out with the bathwater, so to speak, if you find most of the layers are working the way you intended and only need to modify or republish certain ones.
Actually, it was so bad I had to reboot the computer to get ArcGIS Pro to even load again after crashing.
This is more useful, I can start with publish WebMap and drill down to the raster layer and generate the tiles. I can't set to level 23, dialed back to 21.
