Can not connect to ArcGIS Online
10293
26
09-06-2010 10:08 PM
JamieTill
I have installed ArcGIS 10, however the option to sign in is greyed out in the File menu. If I click on ArcGIS Online from the File menu the ArcGIS Online box appears, it waits about 2 minutes and then says "unable to connect to the remote server".
I have tried putting in my username / password into the proxy settings in ArcCatlog, but there was no difference. I just want to use Bing Maps as a base layer. Has anyone else had this issue?
MikeMinami
Esri Notable Contributor
If you're having proxy issues, I'd suggest you contact Esri Technical Support.
However, you don't need to sign in to add a Bing basemap. Choose  File > Add Data > Add Basemap and choose the basemap you want. Alternatively just go to the ArcMap Basemaps group in ArcGIS.com http://links.esri.com/arcgisdesktop/en/arcmap/layers  and click Open next to the one you want.
Mike
JamieTill
Hi Mike,
Thank you so much for your advice, I did the last option and just opened the layer file in ArcGIS and it is working fine.
Cheers
Jamie
FrancisBoscoe
I am having this problem also. I am behind a very secure firewall. I have tried adding user name and password in ArcCatalog, but no luck and I'm not sure what to do next.
Frank Boscoe
UAlbany
bruceocken
I am experiencing the same problem sitting behind a firewall.  Anybody know what website addresses and ports need to be opend up on the firewall?
FrancisBoscoe
Two weeks later: I am still stuck, in case anyone is monitoring this board.
MikeMinami
There are some problems with ArcGIS Desktop 10 connecting to ArcGIS.com through a proxy server. These issues are addressed in ArcGIS Desktop 10 SP1, which is due out shortly.
Mike
RichardMcDonald
Hi all. I just downloaded and applied the service pack and ... no luck. Still get the same error. Whats unfortunate is that there is no indication as to what site its attempting to access so I cannot test it through a web browser.
JanBorovanský
Just want to point out, that this type of error appears also without proxy settings...
Jan
MikeMinami
I'm sorry the patch didn't fix the problem for you. We need more information about your particular configuration, network, etc. to help narrow down the problem. Can you please contact Technical Support and describe the problem you are having? They are better able to help narrow it down than we can do on the forums.
Thanks for your help and patience.
Mike
