Can I limit member privileges of users from outside my organization?
1301
10-30-2017 12:06 PM
PatrickFilyer
I have a few maps that I would like to share with members from outside of my organization on ArcGIS Online. Is it possible to limit their roles so they can't edit the data (i.e. view only)? are there any group membership roles I can use/create to achieve this?
Tags (1)
KellyGerrow
Esri Alum
Instead of limiting the users role, I would suggest limiting the editing capabilities of the layer using hosted layer views:
https://vdot.maps.arcgis.com/apps/Cascade/index.html?appid=84c75208e15e49e48ca2a05410996c7f
This way you control how the content in your app is accessed by who the app is shared with instead of creating a custom role for each user that you must manage.  Build the app and layer with all the needed capabilities that the consumers. There is an edit privilege that can be applied to custom roles, but these do not apply to editable apps shared with everyone.
-Kelly
KellyGerrow
Esri Alum
-Kelly
PatrickFilyer
Thanks for the response Kelly. This is the approach I will take.
PaulLohr
@KellyGerrow
Doesn't each AGOL user have a single role assigned for all content in the organization?
In other words, a user can't be assigned one set of privileges to one hosted layer and a different set of privileges to another, correct?
Thanks for any help.
