Calculating the fields on the web or in arcgis pro does not work
569
11-15-2024 01:44 AM
JavierCMartínezPrieto
every time there is an update in arcgis online, you have to tremble, because you don't know what they are going to end up breaking.
In this case the surprise has been that now it is not able to transform a character string field (which by the way it creates because it feels like it, since it is specified in the import that it is an integer or double, but that already gives for 10 threads how bad the import to the service from excel or csv works). It gives me the following error: Calculating the fields on the web or in arcgis pro does not work.
but this doesn't end here, in argis pro it gives 99999, that error it has when everything is loaded when updating (if something unexpected has happened it says error).
In short, working with esri every day becomes an adventure because you never know that it is going to stop working out of nowhere, while customers complain, because what was offered a couple of weeks ago may stop working with the next update. work....
Javier C. Martinez Prieto
Wait for the surprises to continue, now the configuration you make in Arcgis Pro is not even in the webmaps.
There really is someone behind the wheel in arcgis online, you see it is normal that updates cause so many errors.
A whole day lost at work because nothing works.
By the way, let's see if you put a **bleep** color designer on the heat map ramps, because I have never seen uglier and more meaningless ramps in my life. In addition, the classic green, yellow and red are missing.
NOBODY AT THE WHEEL
The first photo is how it is configured in arcgis pro, the second photo is how it is shown in the webmaps....
This week so many things have failed that I don't know how you are proud to indicate that you have updated, for every new thing 3 broken....
We are still waiting for you to fix the photos in the replays that you uploaded a couple of years ago in another update.
Also ask for 4000 dollars to use the software
Stephanie_F
Hi @JavierCMartínezPrieto Do you have additional information so we can reproduce this behavior or maybe a sample Excel or CSV that doesn't contain any sensitive information paired with your workflow that you can share?
An Esri Technical Support case would also be a great avenue to dig further into this if possible. https://support.esri.com/en-us/contact
