Bivariate Chloropleth Map Legend labels reversed between edit and display
987
02-01-2023 05:25 PM
BY
The tool for labeling the bivariate chloropleth legend appears to be reversed. That is...if the key says I am editing the right label it will actually be the left label, if it says I am editing the top label it will actually be the bottom and vice versa. A bit confusing but manageable with the legend pane that shows at the same time. Just FYI for improving the project, appreciate the bivariate tool, it is great!
RussRoberts
Esri Notable Contributor
I couldnt reproduce this could you share your map?
