attachment link shows original path to attachment
1480
12-05-2012 09:35 AM
AnnMcManus
I have a feature service with attachments. The attachments work fine. Sometimes however in the pop-up, the hyperlink to the attachment merely says the file name (ie. river.jpg) and sometimes the hyperlink says the entire path to the original document (ie c:\users\...\river.jpg). Both work fine but I don't really want the full path name showing up especially considering its not a valid path name once the document is uploaded to the server.
WillCorum
Also seeing this. Anyone else? Know of a fix?
YueWu1
by Esri Regular Contributor
Hello Will,
The issue is because of the security setting for Internet Explorer
Here is way to change the full file path to only the file name:
1. Open Internet Explore and click Tools --> Internet Options --> Security --> Custom level button
2. Confirm that disable "Include local directory path when uploading files to a server." is checked
3. Click OK and try to attach new file. The issue should be fixed.
Hope this can help.
Best Regards,
