Hi everyone,
I'm trying to take some models in ArcPro that I've built, and translate them into a AGOL Advanced notebook. (It'd be a lot easier to just leave this in models, but IT issues cause periodic disconnect from portal mid processes and it corrupts the data) Originally I was building the notebook in pro for testing. However I just tried it in the online environment and am not having any success.
Here's the code (works in an ArcPro Notebook.)
from arcgis.gis import GIS
gis = GIS("home")
import arcpy
line_url = ("https://services8.arcgis.com/kiN57DOJrIhpvBby/arcgis/rest/services/<LineLayer>/FeatureServer/98")
table_url = ("https://services8.arcgis.com/kiN57DOJrIhpvBby/arcgis/rest/services/<TableForJoin>/FeatureServer/0")
arcpy.management.DeleteField(in_table=line_url, drop_field=["Freight", "Price_Per_Foot", "Price_Per_Unit", "Type", "Description" ])[0]
arcpy.management.JoinField(
in_data=line_url,
in_field="Lock",
join_table=table_url,
join_field="Key_",
fields="Description;Price_Per_Foot;Price_Per_Unit;Freight",
fm_option="NOT_USE_FM",
field_mapping=None
And the error (returned in AGOL Notebook, no errors in pro):
ExecuteError Traceback (most recent call last)
Input In [110], in <cell line: 2>()
1 #Drop Fields
----> 2 arcpy.management.DeleteField(
3 in_table=line_url,
4 drop_field="Lock;Description;Price_Per_Foot;Price_Per_Unit;Freight",
5 method="DELETE_FIELDS"
6 )
8 arcpy.management.JoinField(
9 in_data=line_url,
10 in_field="Lock",
15 field_mapping=None
16 )
File /opt/conda/lib/python3.9/site-packages/arcpy/management.py:6025, in DeleteField(in_table, drop_field, method)
6023 return retval
6024 except Exception as e:
-> 6025 raise e
File /opt/conda/lib/python3.9/site-packages/arcpy/management.py:6022, in DeleteField(in_table, drop_field, method)
6020 from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
6021 try:
-> 6022 retval = convertArcObjectToPythonObject(gp.DeleteField_management(*gp_fixargs((in_table, drop_field, method), True)))
6023 return retval
File /opt/conda/lib/python3.9/site-packages/arcpy/geoprocessing/_base.py:512, in Geoprocessor.__getattr__.<locals>.<lambda>(*args)
510 val = getattr(self._gp, attr)
511 if callable(val):
--> 512 return lambda *args: val(*gp_fixargs(args, True))
513 else:
514 return convertArcObjectToPythonObject(val)
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: Dataset https://services8.arcgis.com/kiN57DOJrIhpvBby/arcgis/rest/services/<LineLayer>/FeatureServer/98 does not exist or is not supported
Failed to execute (DeleteField).So my end goal here is to have a table hosted in AGOL that when updated, will update prices in hosted Feature Layers. Then on to field calculates to get price of line based on (feet*price per foot).
I'm deleting fields before joining because if I don't delete, the join just continually adds more sequential fields that do not fit in with the field calculation done later in the script (at least that's how it worked in model builder).
I've also tried gis.content.get, and converting to the FeatureLayer module in this script, and get a different error:
RuntimeError Traceback (most recent call last)
Input In [111], in <cell line: 2>()
1 #arcpy.management.DeleteField(in_table=lineFeature, drop_field=["Freight", "Price_Per_Foot", "Price_Per_Unit", "Type", "Description"])[0]
3 in_table=FuturePipe,
6 )
9 in_data=lineFeature,
10 in_field="Lock",
16 )
6023 return retval
-> 6025 raise e
6021 try:
6023 return retval
513 else:
RuntimeError: Object: Error in executing toolIf anyone knows of a better way to do this or how to get the delete then join function working correctly, I very much appreciate the help.
Cheers,
Matt
