ArcOnline - Creating a Feature Layer with Points, Lines, Polygons AND a Table
1659
09-29-2021 08:50 AM
jmohlman
Hello,
I am new to ArcOnline and am looking to create a Feature Layer & map to use in ArcCollector. My question is how do I build a Feature Layer that has points, lines, polygons, AND a table? Within many of the templates available on ArcGIS Online the Feature Layers include points, lines, polygons, and a table. However, when using the "Build a Layer" option there is only "Points, Lines, and Polygons" or "Table", and you cannot have them together. I have not been able to find any clarity on this online, so any help would be greatly appreciated. I have included pictures below to better explain my question. Thank you!
jcarlson
MVP Esteemed Contributor
Or what about when you want two point layers and a table? And so on.
To get something other than the default templates, you need to create/configure your layers in Pro, then publish them as hosted layers.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
jmohlman
Thank you!
