ArcMap 10.5.1 won't open after splash screen
6059
6
02-02-2018 12:07 PM
Brian_AlexanderChalfant
I've got ArcGIS Desktop 10.5.1 installed on a PC running 64-bit Windows 7.  When I go to open ArcMap - whether from the exe file, an exe shortcut, or an existing project file - the splash screen appears for some seconds, but then the program doesn't open.  I can open some other ArcGIS components (e.g., ArcCatalog, ArcReader) no problem, but others (e.g., ArcScene, ArcGlobe... the "viewer" applications?) act the same as ArcMap:  splash, then nothing.  I tried deleting the normal.mxt file, to no avail.  Any ideas on what's going on and how to fix it will be much appreciated.
Tags (1)
MichaelVolz
Esteemed Contributor
Do you know if the graphics card meets the software requirements?
I think so?
My graphics card is an AMD ATI Mobility Radeon HD 4670 and - according to its ostensible specs (ATI Mobility Radeon HD 4670 specs (Meet Gadget)) - it seems to meet the system requirements for ArcGIS Desktop (ArcGIS Desktop 10.6 system requirements—ArcGIS Help | ArcGIS Desktop... these are requirements for ArcGIS 10.6, not 10.5, but it seems to meet even the requirements for 10.6)... at least it does for RAM (512 MB)... I honestly don't know what the other video/graphics adapter system requirements (24-bit capable accelerator; OpenGL 2.0 and Shader Model 3.0) mean or how to check if my card meets those requirements.
JakeSkinner
Esri Esteemed Contributor
Try holding Shift + right-click on ArcMap's exe > Run As Administrator to see if it opens.
no dice : \
I updated to 10.6 and now no issues...
DrewDowling
I had this exact same problem after upgrading from 10.3.1 to 10.5.1. For me it was also a graphics adapter problem. In my case, somebody had installed both an NVIDIA display adapter/driver and an Intel graphics driver. I checked the Display adapter being used in the Device manager and saw that it was the Intel Graphics driver so I uninstalled the NVIDIA stuff and ArcMap successfully loaded.
