ARcgis online web map Feature service got removed automatically
1903
5
09-10-2018 07:41 AM
Pa_Lotus
I have a Feature service with authentication/login,  added it in web map and saved it.
it works fine, and when i get back after a week or so, feature service was not there in web map and i need to start the process again (add layer from web) and configure it.
why was it removed unknowingly?
RobertScheitlin__GISP
Malla,
   The layer is getting removed because the token for that secured layer has expired.
https://community.esri.com/thread/204521-update-secure-service-credentials-in-arcgis-online
Pa_Lotus
Hi Robert,
Thanks for your reply
this web map is used with in organization, by logging in who has permissions. If i save my login credentials with this web map, then everyone can access this web map. is there any other way?
Malla,
   OK, then there must be some other issue then as the user should just get prompted to sign in to use the web map with the secured layer then. Sorry I am not sure what the issue is then.
MichaelVolz
Esteemed Contributor
Has this behavior occurred multiple times or just once?
Pa_Lotus
two times so far in a month
