ArcGIS Online Vs. Custom Applications?
3217
08-31-2015 09:16 AM
JacobPierson
Hey guys,
I'm relatively new to the world of Web GIS, so I apologize for my naivety.
When would it be beneficial to use ArcGIS Online? How about Custom mapping applications? I'm basically looking for la comparison between ArcGIS Online and Custom Mapping Applications; the pros and cons of each essentially.
I'm aware that ArcGIS Online uses credits, so really I'm more interested in the functionality side of things.
Thanks!
MichaelVolz
Esteemed Contributor
For simple applications AGOL is the way to go as you can configure these apps without any programming experience?  If you need any advanced functionality, then custom mapping applications that require some sort of programming would be the way to go.
ChrisSmith7
Honored Contributor
Is your main goal at this point just to learn? Do you have a background in GIS already?
JacobPierson
Chris,
Mostly just to learn.  Just trying to compare and contrast the two.
ChrisSmith7
Honored Contributor
When you say "custom mapping applications" - are you referring to the JSAPI?
