ArcGIS Online: Tile Layer Not Showing
5639
05-06-2019 06:48 AM
EvanStern
Hello,
I have a tile layer that I have uploaded from ArcMap to my AGOL account (with 17 layers of detail), and have published it so that it can be added to an online map. However, nothing appears when I try to open the map. Only the topographic basemap shows. The tile layer is of a raster, old aerial maps. I found another thread on here that suggested going to Layer Properties > Data Frame in ArcMap and checking "Extent of data in all layers (default)". However, when I went there, it was already checked off. So, now I am unsure what is causing my tile layer not show. Any ideas would be much appreciated.
Evan
KellyGerrow
Esri Alum
Hi Evan,
Can you share the layer? Did you generate the tiles from a TPK or using ArcgIS Online? On the settings tab, have the tiles been built?
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-hosted-tile-layers.htm#ESRI_SECTION1_EC16...
-Kelly
EvanStern
Hi Kelley,
I've gotten to the point where the raster does show up in ArcMap (I published the tiles). However, I don't want the white box around it. Is there a way to get rid of that or is that the best it will get?
MelissaNugent1
Hi - did you ever solve this? I'm having  this same problem publishing from ArcMap 10.5.1 to AGOL.
DanSirk2
I had the same problem. I published my tiles from Drone2Map. The link above had the solution.
