The Map Viewer in ArcGIS Online will only get you so far. You could define an interactive filter on your postal code layer (available from the context menu of the layer), and then display a table of the matching records, but this would be a bit hidden for someone using the map. It sounds like you'll need to write your own application to do this. I'd suggest checking out the various API references.http://developers.arcgis.com/en/javascript/http://resources.arcgis.com/en/communities/silverlight-api/http://resources.arcgis.com/en/communities/flex-api/Thanks,Mike
Signed in members can post, follow updates, and more. New here? Register a free account.
