I have a web map which contains several overlapping points with same address. When I click on the symbology around the center, it gives me option to click on the next feature. If I click around the edges, it does not give me the option. I was wondering if anyone else has encountered this issue. I have been able to duplicate this issue using different symbology.
Here is the link to the web map
https://www.arcgis.com/home/webmap/viewer.html?webmap=2c77cb048a5a491388aa94cf8061d9b9
Popup working correctly
Popup not working correctly
The issue has now been logged as a bug.
#BUG-000113972 Pop-Up fails to display the information for overlapping features when clicked on the edges of a feature.
This really is strange behavior. I hadn't seen it before but I just made a test sample set and got the same results. Maybe this is a bug?
Adrian,
Thank You for taking your time to test it out with your own data. I tried with a different data-set today and I got the same results. It has different effects when using different symbology. Some seem to minimize the issue on desktop browsers but does not completely get rid of it. It is worse on mobile browsers. I contacted ESRI support and did a screen share session. It has not been designated as a bug yet but I will post any updates.
What was Esri tech support's response to this behavior? I presume they were able to reproduce it?
They said they will look into it and will get back to me. I will post any updates.
Just got an update from ESRI and they said they have were able to reproduce the issue with in-house data. It has not been designated as a bug yet but looks like it will be.
