ArcGIS Online New Map Viewer doesn't support WMS Legends
3310
9
09-04-2023 04:20 PM
Marc_Graham
I want to create a web map with many WMS layers from public sources such as: https://geology.data.vic.gov.au/nvcl/wms
I would like to use the new Map Viewer, not the Map Viewer Classic, however the new Map Viewer seems to be incapable of showing WMS legends.
Map Viewer Classic:
New Map Viewer:
Map Viewer Classic in Web AppBuilder:
New Map Viewer in Web AppBuilder:
New Map Viewer (Left) and Map Viewer Classic (Right) in Experience Builder:
Do we know when this is planned to be available, or is there something I am missing to make it work now?
Marc
ZaraMatheson
Hello, WMS Legend support was added in the April Map Viewer update. If you are still seeing issues, please let us know.
Marc_Graham
Looking at the json representation of the two webmaps from ArcGIS Online assistant we can see that the legendUrl for the WMS layer is not added in the New Web Map specification:
while it is present in the Map Json created by the old Map Viewer Classic:
Marc_Graham
Just for fun I copied the legendUrl into the new webmap json using ArcGIS Online assistant and it worked 😖
So this must be a bug/feature enhancement request. Here is the related ArcGIS Idea: https://community.esri.com/t5/arcgis-online-ideas/support-wms-legends-in-the-new-web-map-viewer/idi-... .  If you come across this and think it is worthwhile, please upvote.
Marc
SerjStol
This is an issue for us, we need to use WMS weather service and having a legend is a must!
SaloJo
Any solution here, is there a way around? It is a really big problem for us.
ZaraMatheson
PhilippeDerynck
Hi @ZaraMatheson , will there be a patch for ArcGIS Enterprise 11.3? ArcGIS Enterprise 11.4 is breaking (no WAB functionality) and it will take a big change (and a lot of preparation time)  to upgrade to ArcGIS Enterprise 11.4.
JeffreySutherland
Hi @PhilippeDerynck !
There is no patch currently planned for this functionality in the Map Viewer in ArcGIS Enterprise 11.3. That said, this functionality is available in the new Map Viewer in ArcGIS Enterprise 11.4 (released yesterday on November 7, 2024!).
See screengrab from 11.4 below using the test WMS service provided in the original comment.
It is important to note that that ArcGIS Enterprise 11.4 is not a breaking release with regard to the Map Viewer Classic and Web AppBuilder. Both applications will be available for use in 11.4. For more information on the retirement roadmap for Map Viewer Classic and Web AppBuilder, please see links below:
https://support.esri.com/en-us/knowledge-base/deprecation-map-viewer-classic-deprecation-000030662
https://www.esri.com/arcgis-blog/products/web-appbuilder/announcements/arcgis-web-appbuilder-roadmap...
Marc_Graham
Please consider adding this functionality to 11.3 via a patch. As 11.3 is a LTS release many organizations will be on it until 11.5 is released.
Marc
LievenVerheust
OGC specs are incredibly important in Europe and many organizations who are on 11.3 as a LTS version should get this as a patch. Everybody was urged to move towards the new map viewer but now has to go back for this specific reason. It does not seem as a huge change to include the WMS legend in the new map viewer as a patch since it does seem to work if you manually change the json.
