ArcGIS Online: How to edit “feature access layer” while working in Map Viewer of ArcGIS Online?
997
03-06-2020 10:49 PM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, I wanted to edit a feature in the indicated layer. How this can be performed?
Jamal Numan
Katie_Clark
MVP Regular Contributor
You will need to enable editing on the hosted feature layer, which can be done in the Settings tab of the feature layer's Item Details page.
Note: In order for you to be able to implement edits in ArcGIS Online, your account needs to have editing privileges. (this is determined by user type and role)
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
JamalNUMAN
Many thanks Katherine for the help.
I could enable editing but as editing is applied, I couldn’t figure out how to save the edits!
Jamal Numan
Katie_Clark
Once you close the pop-up, the edits should be automatically saved.
Best,
Katie
JamalNUMAN
It works with me Katherine. Thank you
Jamal Numan
