ArcGIS Online Assistant Copy Online to Portal
6921
11-15-2018 03:10 PM
by Anonymous User
Not applicable
I'm attempting to use the ArcGIS Online Assistant https://ago-assistant.esri.com/# to copy data from Online to Portal.  When Copying, there is an option to copy a reference to the data or to copy the Full dataset.  The option to copy the full dataset is identified as experimental.  I'm reporting that when I attempt to copy a Full data set with multiple layers, it results in a "Incomplete-check console" message.  When I check the copied data, the tables show up with the columns with no rows or sometimes with all the rows but with empty cells.
I appreciate the addition of this option and look forward to this option becoming "less experimental"
If there are any other tools out there to accomplish this, I would be interested in hearing.  Otherwise, I will download and republish.  Thanks
by Anonymous User
Not applicable
Thank you for information about the Pro Tool.  It is interesting that the Tool is no longer being updated with a link to the Python API clone tool https://esri.github.io/arcgis-python-api/apidoc/html/arcgis.gis.toc.html#arcgis.gis.ContentManager.c... but this tool appears to only have a parameter for an output folder which I interpret as only cloning within the same Portal or AGOL.  Nonetheless, I'll try the Pro Tool.  Thanks again.
JakeSkinner
Esri Esteemed Contributor
rachelg_esri
Hello Brian!
I would recommend logging an Issue at the AGO Assistant GitHub page at Issues · Esri/ago-assistant · GitHub . The folks that run that page are the ones who will be best able to assist you with what's going on, and they should be alerted about the issue so they can look into it.
Thank you!
Best regards,
Rachel
Esri Support Services
Rachel Guttmacher
ArcGIS Online Technology Lead
by Anonymous User
Not applicable
Hi Rachel,
Thank you very much. I will let them know.
Brian
by Anonymous User
Not applicable
