ArcGis online and none public web maps ...
1010
01-29-2013 11:27 PM
JanBliki
We try to use ArcGis online as a working environment for producing webmaps. Before we publish content publicly we would like to share this inside the organisation. But this creates a lot of frustration because we get constantly the question to login.
The current setup doesn't allow a real working environment to make this possible. I list some of the daily problems we have.
1) We use ArcGis server to serve map services that then are consumed inside arcgis online. If we need to make these secure we need to ask people to use two accounts. One arcgis online and one for Arcgis server. A web map will ask both passwords all the time making it very confusing.
Solution: Maybe ArcGis server should be able to use the ArcGis online login mechanism and should do this transparently when used from ArcGis online...
2) Templates can't be loaded inside arcgis online making yet another website. These templates can be public but because we jump to another domain it requests once more for the login of arcgis online.
Solution: Maybe allow web templates to be uploaded inside ArcGis online.
Does anybody face the same issues and how did you solve these?
Jan
MikeMinami
Esri Notable Contributor
1) When you add a reference to a secured service to ArcGIS Online, you have the option to embed the credentials. See attached image.
2) Yes, currently we don't support uploading your own custom templates and have them run on our servers. Perhaps in the future.
Mike
