ArcGIS Online Administrators "You do not have permissions to access this resource."
7794
15
06-29-2018 02:15 PM
BillFox
MVP Notable Contributor
I Logged into AGOL as an Administrator today and after selecting the Organization > Settings Tab
This error pops up:
Does this happen for you too?
BillFox
It works fine for a different user with the Administrator role.
The only difference is 100 credits are allocated to the account the works.
If I add just 1 credit to the account that is getting the error it fixes it too.
This user account has worked fine for a long time.
Did something change to enforce credit usage?
KellyGerrow
Esri Alum
Thanks for this information Bill. I can reproduce the issue.
BillFox
Hi Kelly,
yep, tech support can reproduce the issue too
MelissaSalich
I'm have one user in my AGO organization that is getting this error on Title Services only.
Any insight?
Other users with the same user type and role can see the tile services without any issues.
User type = Creator
Role = Publisher
BillFox
do they have credits available?
MelissaSalich
yes, over 1,000 available
KellyGerrow
Esri Alum
can you share the items they can't see? If not, I'd suggest getting in touch with tech support.
KellyGerrow
Esri Alum
Hey Bill,
I'd suggest getting in touch with Technical Support to look into this issue further. Are you able to access the settings tab after receiving the error message?
BillFox
#BUG-000115081 Error message: do not have permissions to access this resource
Status: Implemented
