ArcGIS on Iphone not showing historic 1903 map, shows much more recent historic map?
1066
01-03-2021 10:37 AM
AmericanGeode
I have the free account  version 20.0.1 build 2647 on iPhone. I have downloaded a 1903 Dahlonega, Georgia map from USGS Historical Topographic Map Explorer, but when I try to pull up that 1930 map, it pulls up a 1980s map from the same area. Does my account not allow maps that old? I have also tried this on an Android, and the same. Thank you for any insight.
RandyBurton
The historical map is probably using time animation.  You may need to adjust the time slider to the appropriate period or select "disable time animation" when creating your map.  If this does not apply in your case, then sharing a bit more information on how you created your map would help in providing solutions.
AmericanGeode
Thank you for this insight. Never occurred to me to check those settings, and had not paid attention to time animation, but I do not require it. Thank you very much again.
