ArcGIS for Sharepoint can't access ArcGIS Online Web Maps shared with Organization
1096
5
12-19-2012 09:15 AM
MikeGregotski
I???m trying to use ArcGIS Online Subscription web maps containing ArcGIS Online Subscription feature services in ArcGIS for Sharepoint 2.1.1 and I???ve run into some trouble.
I have a web map that is shared with Everyone and contains a feature service that is also shared with Everyone. I can add this to the ArcGIS Web Map Part in ArcGIS for SharePoint through the Map Center successfully.  This is good.
I then have another Web Map that is shared with the Organization only and it contains a feature service that is shared with the Organization only.  When I try to add it to the ArcGIS Web Map Part in ArcGIS for SharePoint it gives me this error.
Layer Initialization Failure
Token Required
Error code ???499???: ???Token Required???
It seems that ArcGIS for Sharepoint can???t handle the token security that is being used by ArcGIS Online.  Has anyone got this to work before or know if this is a limitation to using ArcGIS for Sharepoint with ArcGIS Online?
Mike
MikeMinami
Esri Notable Contributor
I've checked with our Sharepoint team and have been told that this is a known limit.
Mike
MikeMinami
Mike
MikeGregotski
Thanks for letting me know about this Mike.
Mike
NickJohnson1
Mike
Hey mike,
As u said it is a known limit, I want to know that sharepoint developers are doing something or not to overcome this limit???????
It will be very nice if u could help me with this......
MikeMinami
What do you want to happen? Do you  want a prompt to display to enter a username and password?
Mike
DougCampbell
Hi Mike,
I'm just hitting this wall today. For my part I think it would be best if it were possible to specify the credentials in the ArcGIS for SharePoint Administration area. Under connections entries there I would want to expand to properties of the panel to provide credentials there for each source that needs them. Thoughts?
