You can change the basemap choices when using the embedded map or Basic Viewer template but you'll have to append some url parameters to the url. To change the displayed basemaps you need to create an ArcGIS.com group that contains the basemaps you want to appear in the gallery. Once you've done this you can apply this information by adding the following parameters to your url. The basemapGroupOwner will be the owner of the new group you created and the basemapGroupTitle is the title. https://team.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=422dca2738b941cb8f5fd3f1b010969c &basemapGroupOwner=Kelly &basemapGroupTitle='Basic%20Viewer%20Basemaps'
Here is an interesting one where I used the Bookmark for Apalachia and then panned. The selection outline is in the correct location, but the purple polygons did not catch up.PJ
PJ,I can reproduce your drawing problem. I'm not seeing any problem when testing your map against our development servers, so I believe it will be fixed by the end of next week. If you still see issues after next week, let us know.Thanks,Mike
Issue 3. When using an imbedded map or the Basic Viewer web app template, why do the BaseMap choices not have the USA Topo Map? Can we replace the Oceans choice (which is irrelevant for our area) with USA Topo Maps? http://tva.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=e2eda485b1a2478798d1f6616eae308d
"http://services.arcgis.com/w8auYAijfGK1Mydj/arcgis/rest/services/Dispersed_Rec_Areas_dissolved_mp/FeatureServer/0?token=vfJxpSnJ0R8maHzAVbqmYx_JPErPWO8oqn_OBuyc3rukuzhEd2Va0lN9zukPb75Q",
Signed in members can post, follow updates, and more. New here? Register a free account.
