I'm kinda noob in arcade. I'm trying to achieve an interactive map where a person clicks on a parcel and pop-up shown information about whether the land is affected by any restrictions or what land-use it is in. Unfortunately, a parcel can be in two or more land-uses/study area etc. and I don't know how to display information for more than one variable.
Showcase is for study area. I'm using arcgis online map viewer pop-up arcade ("newly" allowing use html).
- If parcel is in 0 studia area, pop-up shows nothing (correct),
- if <0 or =100 area of parcel is in 1 study, pop-up shows how much % of area of parcel is in study area + info for the study + common info for all studies (correct)
- if cnt > 1 it show header (hlavicka) of table + common info for all studies but nothing between
I would like to achieve of format:
■ X% of parcel in STUDY AREA:
US.01
US.02
■ Insert study US.01 info
■ Insert study US.02 info
■ Common info for all studies
I know its kinda confused in "var DefUS01 = IIF(percentage > 0 && US_info == 'US.01'" because if it's cnt > 1 → US_info is in format:
US.0X
US.0X
so it's not gonna find any match. If i ty to use IIF(percentage > 0 && Find('US.01', US_info) it's failing too. I need something to to say "if % of area is bigger than 0 and you find value US.01 in US_info return text.
It's even possible to achieve something like this without changing attribute table for easier value calling?
var prunik = Intersects((FeatureSetByName($map, "Územní studie")), $feature);
var cnt = Count(prunik);
var intersectArea = 0;
/////////Calling study ID + info
var US_info = ""
for (var US in prunik) {
if (US_info == "") { US_info = US.Id; }
else { US_info += "<br>" + US.Id; } }
if (cnt > 0) {
// we have overlap
for (var prunikArea in prunik) {
// intersect with polygon, and add area to the total
intersectArea += Area(Intersection($feature, prunikArea), "vymeraparcely");
// calculate the percentage of overlap
var zoneArea = Area($feature, "vymeraparcely");
var percentage = Round(intersectArea * 100.0 / zoneArea, 1);
// format the resulting text for > 0 < 100
var result = "<tr><td>■ " + percentage + "% of parcel in <strong>STUDY AREA - " + US_info + "</strong>. " + "</td></tr>";
//format conditions for final text
var hlavicka = IIF(percentage > 0, "<table><tr><th>Územní studie</th>", "")
var RegIN100 = IIf(percentage == 100, "<tr><td>■ Parcel in <strong>STUDY AREA - " + US_info + ". " + "</strong></td></tr>", "")
var RegIN = IIF(percentage > 0 && percentage < 100, result, "")
var konec = IIF(percentage > 0, "</table>", "")
var DefUS01 = IIF(percentage > 0 && US_info == 'US.01', "<tr><td><br>■ <u>Insert study US.01 info</u></tr></td>", "" )
var DefUS02 = IIF(percentage > 0 && US_info == 'US.02', "<tr><td><br>■ <u>Insert study US.02 info</u></tr></td>", "" )
var DefUS04 = IIF(percentage > 0 && US_info == 'US.04', "<tr><td><br>■ <u>Insert study US.04 info</u></tr></td>", "" )
var DefUS05 = IIF(percentage > 0 && US_info == 'US.05', "<tr><td><br>■ <u>Insert study US.05 info</u></tr></td>", "" )
var DefUS06 = IIF(percentage > 0 && US_info == 'US.06', "<tr><td><br>■ <u>Insert study US.06 info</u></tr></td>", "" )
var DefUS07 = IIF(percentage > 0 && US_info == 'US.07', "<tr><td><br>■ <u>Insert study US.07 info</u></tr></td>", "" )
var OBECust = IIF(percentage > 0, "<tr><td><br>■ Common info for all studies</tr></td>", "")
///////// Final Text
var finalText = hlavicka + RegIN + RegIN100 + DefUS01 + DefUS02 + DefUS04 + DefUS05 + DefUS06 + DefUS07 + OBECust + konec
return {
type : 'text',
text : finalText //this property supports html tags
If intersect with 2 study areas - not working
If intersect with part of the study area - working
If intersect with 1 study area (100% intersect) - working
