Arcade Expression for Mailing Labels in Public Notification Widget
3116
14
06-01-2020 06:53 AM
KellyArmstrong
Here are my fields:  [building_number], [street_name], [street_type], [street_direction], [city], [state]
I am trying to create an expression where, if the field [building_number] is empty, don't show any fields.
Else, return something like this:
Resident
[building_number] [street_name] [street_type] [street_direction]
[city], [state]
XanderBakker
Esri Esteemed Contributor
Hi OakdaleGIS ,
This is due to the fact that the newline is not supported yet. This will come in the near future.
XanderBakker
Hi OakdaleGIS ,
Could you try this?
if (IsEmpty($feature["building_number"])) {
    return "";
} else {
    return "Resident" + TextFormatting.NewLine +
    Concatenate([$feature["building_number"], $feature["street_name"], $feature["street_type"], $feature["street_direction"]], ' ') +
    TextFormatting.NewLine + $feature.city + ", " +  $feature.state;
KellyArmstrong
Xander,
It works great.  Only issue is after the concatenation, the elements have no spaces between them...
Thank you very much!!
KellyArmstrong
Xander,
It does work.  I was just seeing the concatenation in Arcade, when I actually utilized the expression, it worked with spaces.
Many many thanks!
KellyArmstrong
Xander,
Actually, now that I have used/called the expression in the "Public Notification" widget, it does not function:
XanderBakker
Hi OakdaleGIS ,
Could you look at the actual content of the building number field where you see this behavior? I am using the IsEmpty function and when the field is not actually empty it will not work. If the field is string, please check that there are no spaces in this field, since it will not be detected as empty.
KellyArmstrong
I am not finding any spaces.  How would you check?  Also, this is a service from our ArcGIS Server, not a hosted feature service from AGOL.
MichaelVolz
Do you have access to the datasource of the AGS service to review the raw data in ArcMap/Pro to look for blanks?
KellyArmstrong
Yes, the service is located here:  Service
field:   parcel_building_number ( type: esriFieldTypeString , alias: /\BLDG_NUM/\ , length: 10 )
KellyArmstrong
I don't see any spaces...
