Anyone ever receieved this locked icon before when attempting to edit a hosted feature layer table in AGOL? I have been working with this dataset without issue, and this just began without prompting. Anyone ever receieved this locked icon before when atte
10515
10
03-02-2017 12:53 PM
MichaelRawitch1
MichaelRawitch1
Lily, I just found that it was an issue in the settings. I was only allowing new data to be created, but not updated. The issue has been fixed now.
KellyGerrow
Esri Alum
Hi Michael,
That icon indicates that the fields are un editable. Are you able to share your service url to this post? How did you create the service?
-Kelly
MichaelRawitch1
Kelly,
I have editing enabled in both the drop More Options dropdown menu from the Content pane as well as  settings in the Feature Layer (hosted)settings. I wasn’t having any issues with this until I exported a FGDB to My Content, and then the whole thing froze up. I also performed a synchronization with some offline data but didn’t actually make any edits.
The service was created a point feature layer (hosted) for Collector. It has been in use several weeks and has several hundred attachments and points. It is shared with a Group, and I have modified the domains using the JSON script earlier today but had no issues following this update.
Here is the REST API, but I don’t think you will have access to this since the information requires a company log-in.
https://services3.arcgis.com/NqGokVvI0NQ6O9Jf/arcgis/rest/services/Dwyer_AGOL_20170227/FeatureServer...
KellyGerrow
Esri Alum
Thanks Michael,
I removed the token so that no one else can access your rest url, but it looks like the fields with the lock box are editable from the rest end point. Another place where you can disable editing is through the pop up configuration in the visualization tab or the map viewer. You can select Configure Pop up>Configure Attributes and then check on or off the capability to edit specific fields. If the edit option is checked off, you will also see the lock box in the data tab.
Try checking the pop up configuration to turn editing back on for the fields that you were displaying.
-Kelly
MichaelRawitch1
CharlesRobbins3
I'm thinking this should also be on the "Data" Tab in the "Item Details" of the service.  Accessing the edit rights from the Map Viewer only is sorta out of the way, it's great to have it there if you are in a map, but sometimes you just need to edit data from the table view.
JoeBryant1
I agree; this should be an enhancement request. I've been looking all over for where to turn this stupid field lock off from.
BrookeAumann
Did you ever find it? I've done everything mentioned in this thread and my fields are still locked. I'm not a JSON person, so I don't know how to fix it on the backend.
KellyGerrow
Esri Alum
HI Brooke,
How is your pop up configured? What editing capabilities are present in the settings tab of the feature layer?
-Kelly
BrookeAumann
Hi Kelly,
My pop-up had those fields as being un-editable, but I changed that, and I still had locks (but the locks were in Data>Table if I looked at it in the Feature Service details which is where I wanted to calculate fields). I was able to calculate the fields, after I made them editable, in the web map version of the table. I had exported the data previously, so maybe that's why they are locked in the Data>Table view?
