AGOL- Where are my geocoded addresses?
1048
11
03-15-2019 03:21 PM
JoeBorgione
I uploaded an xlsx file of restaurants and their respective addresses to my AGOL account. I accept the geocoding processing and use our own (not ESRIs global) locating service.  It tells me that 214 address are good, but two are not.  Good.  That's what I expected.  I then accept the suggestion to review the addresses, and it takes me to a map view.  So far so good.
However, when I attempt to alter the two non-located addresses, nothing really happens. Following  the help page , I enter the corrected address in the table, and hit enter.  It still gives me the same world-wide suggestions it originally did.  On top of that, the 214 points that allegedly geocoded are no where to be seen on the map.  I can 'zoom to the layer' and the extent is correct, but no points appear.  But....  Back at the item details page, I can click the Visualization button, and they magically appear.
I've probably geocoded millions of address records using ArcGIS Desktop: 15 years or so in 9-1-1 will do that to you. This xlxs worksheet geocodes just fine in ArcGIS Pro 2.3 with the same locator: so what's the trick in AGOL?
That should just about do it....
JoeBorgione
Forgot to add this little bit of AGOL wisdom:
Yeah...  I know...
KellyGerrow
Esri Frequent Contributor
Hi Joe,
I'm not sure on this one, can you get in touch with tech support to dig into this further?
Shana Britt
Robert Jensen
-Kelly
JoeBorgione
Will do.  Thanks!
ShanaBritt
Joe, did you end up reaching out to Support?
JoeBorgione
Not yet...  Probably today; I'll keep you posted...
Shana Britt
ShanaBritt
Joe, you likely need to provide the spreadsheet for investigating the problem.
JoeBorgione
Shana & Kelly-  I have a brown shirt on today; the last time I tried to upload an xlsx worksheet and geocode it on the way I had a blue shirt on.
Today, I was able to upload the same worksheet, use the same locator, and now I can see my 217 points in a map view.
I guess brown is my color...
Shana Britt
Kelly Gerrow
KellyGerrow
Hi Joe,
Thanks for your beautiful poem. It made me chuckle
I would still suggest having this looked into as I wouldn't want you to have to wear brown for the rest of your life, just in order to geocode. If you continue to have issues when you are wearing other colours, I'd suggest using fiddler or developer tools to capture the network traffic. That way tech support can help investigate the calls made to the API and discover if the nature of the issue.
Here is a link about using fiddler https://community.esri.com/groups/technical-support/blog/2018/06/07/monitoring-web-service-requests-...
-Kelly
JoeBorgione
I downloaded and installed Fiddler, but with it running I'm not able to get to a login screen for AGOL.  I had my friend and colleague James Burton (who is wearing a green shirt today) try to upload and geocode the same spreadsheet with the same locator (that worked for me earlier) and he is unable to view the geocoded points and gets the same little pearl that the layer did not draw completely.
Sigh....
