AGOL Table Field reorder -- does not save
1095
13
10-06-2025 01:55 PM
ScottJones1
I am trying to reorder the fields in a table, I can turn off visual and reorder, but if I bounce out and back in, the order does not stay. In field view there is no option? I reordered in pop up and saved but it does not hold when I re-open the table? am I stuck with this order? I don't even think it holds the order when I re-order in PRO
ScottJones1
I guess I am just not getting it, when I open the layer in VISUALIZATION, there is no TABLE option? I have tried moving the fields in MAPVIEW, ARCPRO, DATA VIEW , POPUP orderand every other place to move. But everytime I view in DATA, they go back to the order it starts with. Why this might be an issue, is others may have to edit entries, and when they dont follow the flow it will make it difficult to have to bounce around.. interestingly when I opened in Arcpro, the fields were actually in the correct order. So I will just create the excel sheet from there...
RhettZufelt
MVP Notable Contributor
After seeing this screenshot, it appears that you are in Portal, not AGOL?
I don't know if this option existed when Visualization tab was still opening in Classic like your screenshot.  I don't see it in Portal 10.9.1....
In AGOL, Visualization tab has access to the Layers, and then the table:
R_
ScottJones1
Not sure, I am entering VIA AGOL, thanks for trying, I will figure out a work around, if it is even needed...
RhettZufelt
That is weird.  The snapshot I provided last is what i see in the Visualization tab in AGOL, but I see the same as yours in Portal 10.9.1.
Perhaps an org setting or something?  Afraid I won't be able to help with that one.
R_
