Bumping up for some help using 10.4. Same issue.
Ifeoma,
Which version of StreetMap Premium are you working with? Do you have all three components of the address locator (*.loc, *.lox, *.loc.xml) in the same folder?
Hi Shana,
I worked with an ESRI tech to figure out the problem. I had to rename all 3 components of the address locator (.loc, .lox, and loc.xml) file to have the same file name in order to get the geocoder to work.
Ifeoma:
When you received the locators did the associated files (.lox, .loc, .loc.xml) not have the same names? Is the solution from Support working for you?
-Shana
Yes, when I got the locators, they did not have the same names. The solution from the support team worked for me!
Signed in members can post, follow updates, and more. New here? Register a free account.
