Addition to above Survey 123 question
976
07-05-2019 02:46 PM
CatherineBradley
Here is an addendum to the above question:  The other survey appeared in my map, but I don't know how it got added.  Also, below is a screen shot of my table of contents.  What are the bottom 2 files?  How did they get there & OK to delete?     Thanks again, Ca.
Table of contents in Survey 123
LanceCole
MVP Alum
Catherine,
Those are the underlying metadata tables for the two surveys you have loaded into your session, DO NOT DELETE THEM.
by Anonymous User
Not applicable
Adding a link to the other question you reference above. https://community.esri.com/thread/236377-adding-a-newly-created-survey-to-an-existing-map
LanceCole
MVP Alum
Catherine,
CatherineBradley
Thank you!  Ca.
