Adding XY Coordinates from a table (.csv) file into ArcMap using Python
4531
8
05-01-2020 08:20 PM
ShalinR
I do not where I went wrong here. Please help me.
import arcpy
import fileinput
import string
import os
from arcpy import env
env.workspace = "P:\GEOG - Programming in GIS\Final project\Data"
env.overwrightOutput = True
outpath = "P:\GEOG - Programming in GIS\Final project\Data"
newfc= "Results/NewPtssss.shp"
arcpy.CreateFeatureclass_management(outpath, newfc, "Point")
infile = "P:\GEOG - Programming in GIS\Final project\Data\coordinates.txt"
cursor = arcpy.da.InsertCursor(newfc, ["SHAPE@"])
array = arcpy.Array()
for point in fileinput.input(infile):
if ":" in point:
x, y = string.strip().split(":")
array.add(arcpy.Point(x, y))
cursor.insertRow([arcpy.Point(array)])
fileinput.close()
del cursor
I get the following error:
File "P:/GEOG - Programming in GIS/XYToPoint_Practice.py", line 18, in <module>
File "P:\ArcMap\Desktop10.7\ArcPy\arcpy\arcobjects\mixins.py", line 1122, in __init__
setattr(self, attr, value)
File "P:\ArcMap\Desktop10.7\ArcPy\arcpy\arcobjects\_base.py", line 89, in _set
return setattr(self._arc_object, attr_name, cval(val))
RuntimeError: Point: Input value is not numeric
DanPatterson_Retired
pnt = "1.1:2.2"
coords = pnt.strip().split(":")
x, y = [float(val) for val in coords]‍‍‍‍‍
x, y
(1.1, 2.2)
For your immediate problem, you weren't splitting the point (pnt) into its constituent parts properly,
python's "split" returns a list of string values,
They need to be converted to 'float' values before you pass them on to arcpy's Point object.
/blogs/dan_patterson/2016/08/14/script-formatting
Format your code so indentation can be checked and people can answer with respect to line numbers.
pnt = "1.1:2.2"
x, y
(1.1, 2.2)
ShalinR
Sorry about the formatting. Never previously posted a question of this nature. Thanks for the reply. So am I replacing the code example you provided for line 14?
Katie_Clark
MVP Regular Contributor
One quick thing I'm not sure if you already noticed (it's not directly related to your error message), but you have a typo in the beginning....should be env.overwriteOutput, not env.overwrightOutput
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
ShalinR
Thanks for catching my mistake. So I ended up using another script, which I'm attaching to the reply, and I got no errors. But the problem now is that the point shapefile prints points nowhere near the shapefile of the state that I am trying to plot them onto.
ShalinR
Whoops, made a mistake with latitude and longitude, will let you know if that was the mistake I made.
ShalinR
That was it. All the points are where I needed them to be. Thanks for all your help Katherine Clark @Dan Patterson
JoshuaBixby
Please mark a reply as Correct or mark the thread as assumed answered to close it out.  Also, make sure to mark Helpfuls for comments that were, well, helpful.
