Adding point data via CSV to new map viewer
3673
6
03-03-2022 09:08 AM
Labels (2)
Rhonda_Houser
Esri Alum
A useful, common task for myself and those I supported in our user community, was adding point data via CSV file to a map. In the new map viewer, I only see an option to add from URL, where in classic viewer you can add from a file (on a computer). Do you expect users to load their data onto OneDrive or other cloud storage? If there is no option to add CSV from file going forward, you will leave a lot of people behind (when classic viewer is no longer available), especially those new to AGO and web mapping. Thanks for considering this comment.
ReeseFacendini
Esri Alum
Are you using Enterprise with the Map View Beta or ArcGIS Online?
Rhonda_Houser
Esri Alum
ArcGIS Online
ReeseFacendini
Esri Alum
This screenshot shows the options available for adding data to the new Map Viewer in ArcGIS Online. Do you not have the option at the top for CSV?
Rhonda_Houser
Esri Alum
Yes, I see that, as I described initially. Once I choose CSV, I can only add from URL and not from file/device, as I need to. Thanks.
ericmseitz
I'm in the same boat. Did you every figure this out? Perhaps it is the license I have, through my organization?
Rhonda_Houser
Esri Alum
A friend in GIS with education license said first add it to your content library in AGO. Double-check it won't add directly as I was trying as there have been software updates since then.
