Adding images to titles in popups / multiple images per popup - possible?
2434
07-01-2014 03:01 AM
DanCooper
I am trying to add images to the popups on a AGO project.  I have managed to add images and link them using the Image option in Configure Pop Up.  However I am tasked with adding two images per pop up, both to be seen in the one screen; the idea being we can have a logo for a site and also a photo of said site.  I have read http://storymaps.esri.com/downloads/DesigningWebMapPopups.pdf that you can use html img src to show images in the title part when configuring the attributes list, however this does not seem to work for me, any ideas?
Thanks in advance
MikeMinami
Esri Notable Contributor
You can add multiple images to the popup, but can't view more than one simultaneously. They have to be viewed individually. How about merging the logo onto the image so you end up with just one image? Other than that, you'd have to create a custom application that didn't use the popup.
thanks,
Mike
DanCooper
Thanks Mike,
As I thought, though hoped there may be a sneaky work around.  I'll either merge images or see if one of the templates can help me what I need to achieve
