Adding ArcGIS online layers to Arcmap 10 problem
1139
03-06-2012 02:51 AM
EwanPurser
Does anybody know why when adding layers from ArcGIS online into ArcGIS 10 (using File menu, ArcGIS Online...) it insists on loading them into a new project each time - you cannot add layers into an existing project.
You could do this without a problem in 9.3.
Can this be corrected?
Many thanks
SisiYan
Instead of using the file menu, you can use the [ATTACH=CONFIG]12441[/ATTACH] to add the online content to the exsiting project.
EwanPurser
Perfect -problem solved -Many thanks!
