Adding a printing service to a Portal Map?
4340
07-21-2014 09:38 AM
ThomasColson
Either I'm missing the obvious place where this is documented how-to, or its not possible? I currently  have a GP service on my ArcGIS Server, works great when tied to a Flex Map in a browser. Users can "print" to several formats, either 11 by 17 or 8.5 by 11, using our organizations REQUIRED map template for publishing printed maps.
I'm migrating my content to Portal, and would like the same functionality.....users can open a map....and there is a "Print" feature....that enables the user to print to PDF, JPG, etc...using the Map Template I've previously set up. The default "Print" button and its output in Portal is horrible.
Is this even possible?
DivyamGulati
Hello Tom,
ArcGIS.com and Portal for ArcGIS.com map viewer do not support custom print templates. No matter what template you choose, you will always get the print in MAP_ONLY.
A good approach would be to create a web mapping application like Basic Viewer template to share your content (webmaps) which support custom print templates.
-Best from Divyam.
