How do I add water utility symbology to a map in arcgis online?
You can download the utility style here
https://jsapi.maps.arcgis.com/home/search.html?restrict=false&sortField=relevance&sortOrder=desc&searchTerm=owner%3A%22styles_esri%22+Utility#content
How to set them to your org is here
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/use-published-2d-symbols-in-arcgis-online/
Greetings @Ivy_Hinson
And if you want to take your Water Utilities to the 3D realm, please check 3D Workflows: Utilities
How do you bring in the downloaded symbols? The second link seems to explain how to create and save your own. Thanks.
If you try to bring in the stylx layer through the styles folder, arcpro doesn't seem to see the stylx file. Is this a glitch that is being addressed?
Bring them into Map Viewer after publishing or into Pro?
I am using 3.4 version of Pro and am not Seeing that issue under Styles folder in Pro Add > Add Style
Yes, this is for Pro. I found my way to this string looking for downloading symbol options.
They don't seem to work in pro. I changed the file name to .STYLE and it will bring them in but not work. Pro won't find the .stylx layer.
If you are using import it will show the .style files. If you are using the Add it shows the stylex
Signed in members can post, follow updates, and more. New here? Register a free account.
