Add Space Between Combined Fields in Field Calculator
18793
34
05-07-2018 07:30 AM
JRAdams
In the ArcGIS Online field calculator I am trying to combine a few other fields into one (address field) and cannot figure out how to put a space between the fields. I am sure it is something simple, but I am unable to find the answer elsewhere. Please help! I've tried everything I can think of.
Thank you!!! AGOL Admin fieldcalculator #arcgisonline
DanPatterson_Retired
Is field calculation in AGOL restricted to Arcade?
Then is the best suggestion is to do the 'work' of field concatenation in ArcGIS PRO or ArcMap?  (where you have options, like superior Python )
JoeBorgione
Dan- if a a feature service is hosted on AGOL, you are limited to playing by the AGOL rules. I've done python calculations (my preference; your influence) in ArcGIS Pro on feature services hosted on our own portal....
Dan Patterson
MikeMinami
Esri Notable Contributor
I was able to make the two suggestions above work in HTML view (highlighted yellow below) of a custom popup, outside of the arcade expression. The paragraph padding method worked better, as the non breaking spaces were converted to spaces the next time I edited the popup configuration.
Mike
DougBrowning
MVP Esteemed Contributor
Oh I was doing it in the return statement.  That is where I use my \n.  I do this so that I have a return of '' it does not leave a blank like for no reason.
Adding HTML is a bit of a pain.  Whenever I go back in to edit the popup it changes back to just text and then wipes any custom HTML.
MikeMinami
You have to click the HTML view option to view the HTML. That being said, I found that the paragraph style with padding persisted in HTML view whereas the & nbsp; would disappear.
