accessing private ArcGIS online maps
7506
10
11-15-2011 10:46 AM
danbecker
Have a map saved on arcgis online that has a few shapefiles added to it. This map is only viewable to a private group, not the public.
Is there any way to reference this map 'service' from a template on our webserver? I'm able to successfully view a public map service from ArcGIS online by copying the public mapid and inserting it into the template index.html.
I also tried to generate a token as explained in this guide, and was able to get the username/password login when accessing the template, but all username/password entries fail?
http://help.arcgis.com/en/arcgismobile/10.0/apis/iphone/AppGuide/Maps.pdf
is this even possible?
thanks!
ps. sorry for double-posting the issue, but the other thread was referring to https (SSL) secure ArcGIS Server resources.
AdamJoseph1
you can also install cartoview www.cartologic.com/cartoview and define simple arcgis services which you can use directly in your web application
