3D scene layer does not show up in scene viewer
1347
09-14-2023 04:09 AM
BrieeC
I'm trying to upload a 3D object that has a texture on to AGOL Scene Viewer, I drew the 3D object in ArcPro and loaded a image as a texture, then I converted it into a layer file (attached) and then a scene layer content to be uploaded on to scene viewer. However nothing is showing up.
kiral9
I suggest to post this in GeoNet so the Esri-types can review and give feedback. There could be several things going on here https://mobdro.bio/
- The layer can be set to below the Surface
- The layer can have a Vertical offset
- When you move the cursor you are not Saving the Edits so the Sketch is lost
BrieeC
Thank you for the suggestion, it was set below the surface and therefore not showing it.
RussRoberts
Esri Notable Contributor
Few questions:
Did you publish a hosted scene layer from a scene layer package?
If you generated a scene layer package do you see the feature when you add the scene layer package into pro ?
If you bring the scene layer published back into Pro do you see the feature?
Can you share the scene layer?
