Public Notification widget - zoom to extent of buffer when search distance applied
1985
05-04-2018 01:37 PM
Status: Open
by Anonymous User
Not applicable
When a user applies a search distance to an address I searched, the map should automatically zoom to the extent of that buffer so the user doesn't have to manually zoom out to see the results. Right now the map extent doesn't change and it's not immediately apparent that the search distance was applied. At least make this a parameter in configuration of the widget if it doesn't fit for default behavior.
Edit: Alternatively or additionally, add a zoom scale configuration for initial feature or address search that is part of the widget.
4 Comments
ChrisBuscaglia
Hello Evan,
Thanks for the feedback, I've added this as an enhancement for a future release.
Thanks
Chris
AzizaParveen1
This was implemented in ArcGIS Online 6.3 release, September 2018.
by Anonymous User
Thanks. Do you know what version of Portal this will make it in to? or maybe already has?
AzizaParveen1
Hi Evan, it should be available in Portal 10.7 version.
