Preserve Global ID Outside of Enterprise GDB
569
12-13-2024 07:08 AM
Status: Open
AnninaRupe1
I need this capability to move existing data to new versions of my Tool (see my project summary below). The data are all hosted and I think some of the workarounds I tried messed up some of the data, so I have to manually migrate and make sure the data are correct.
  • I have created a Tool using Survey123, web maps, hosted feature layers, ExperienceBuilder, and Microsoft Power Automate. There are several purposes of this Tool: 1) collect data regarding a landowner's interest in implementing conservation practices on their land (using 3 different surveys (with polygons) with 1 being the "Master" version that the other 2 write to and Microsoft PA), 2) keeping track of landowner contact information (survey), 3) tracking outreach efforts (using 5 different surveys with 1 being the "Master" version that the other 4 write to; point or no geometry), 4) tracking a project's implementation progress (Web maps, ExB, hosted feature layer), and 5) copying data into our organization's main reporting database (Microsoft PA). Data collected in Task 1 is also written to the "Master" database in Task 3 through Microsoft PA (more on this later). The Tool has been constantly evolving; it started out as a preliminary Tool for testing purposes, then in July I migrated the data to a production version (successfully) and now am finishing up version 2.
    The data collected in Task 1 above is automatically copied to the layer in Task 3 (minus the geometry). The reason for this is to streamline reporting. The sites in the data in Task 1 can reference the same sites in Task 3, and vice versa. When there is outreach being done on a site that already has been referenced, the user fills out a survey that is automatically attributed with the GlobalID of the original record (using URL parameters). I have configured the attribute table in a map/app that when selected in the map, the user can see all records that reference the selected site, based on that GlobalID.
    The problem I'm running into is that when I need to migrate data from one version of the Tool to the next, the GlobalIDs change, but the attribute that I have created (containing the GlobalID of the original record) doesn't update, too. So, the link is broken. At this point, I have just under 500 records and have to manually update this value, which is not easy. I did have a workaround the last time I had to migrate data (see this Esri Community post), but as mentioned in update 2, it doesn't work anymore, and the subsequent "fix" did not work for me.
2 Comments
JesseCloutier
Hi @AnninaRupe1, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
AnninaRupe1
I have been directed by Esri Support to place this idea on this page.
The Technical Support Team said that the file geodatabase does not currently support this functionality (this is expected), but the enterprise geodatabase does support it. Therefore, I'd like to suggest implementing this feature in future patches.
I am continuing to work with the Support Team on this as well.
