Limit Cluster Legend to Integers
404
12-08-2022 11:20 AM
Status: Open
PeterKnoop
MVP Regular Contributor
When using Clustering in the Map Viewer, it defaults to displaying a count of features. Since counts are inherently integers, the legend should also be limited to integer values.
If the range of the values being clustered contains fewer than 5 distinct integers, then it should reduce the number of legend items to maintain each being an integer.
If the range needs breaks, then those breaks should also be integers; adjusting the number of items in the legend to accommodate the range.
For example, if you happen be viewing an extent where the count of features ranges from 2 to 3, then the legend should only have two values in it: 2 and 3. It should not display fractional values, as it currently does:
It is confusing to indicate fractional counts, as it is impossible to have a fractional count. Furthermore, there are no symbols on the map that are not 2 or 3, so it overly complicates the legend to have those fractional values presented.
2 Comments
RussRoberts
Yup what we would need to do in this case when you get down to this scale with clusters is drop the number of classes from 5 down to 2 or 3. This could be jarring for some users for viewing the legend while panning and zooming but would have symbols represented the whole number values.
PeterKnoop
@RussRoberts as the legend values are already potentially changing when you pan/zoom, I would suppose that this would not be any more jarring than what the user is currently experiencing. I might suggest that the number of legend values changing provides a stronger visual cue to the user that the legend can update on the fly as they pan/zoom.
