Group template for layers in AGOL
1962
01-02-2024 08:31 AM
Status: Open
AlfredBaldenweck
MVP Frequent Contributor
Kind of related to this Idea, and a way I think it could probably be implemented. Create Buffer/Geofence Around Points in Field Maps - Esri Community
In short, I would like Map Viewer to have a group layer tempate.
In Pro, you can use group templates to create multiple associated features from different layers at once.
I would like to do this in AGOL (and then in FieldMaps) to speed up the editing process, as well as do some of our data processing in advance; no need to manually buffer when you can populate the associated feature class automatically when you place the site.
3 Comments
SergioSalmeron_NTT
In addition to AGOL, also for Argis Enterprise with the JS widget editor
rohanrajan_hms
I actually came across this error while trying to publish a web layer with Group Template, 24081: Group templates are not supported—ArcGIS Pro | Documentation. But, in ESRI UK's Utility Network Editor demo video they display a group template option but did not create any features. I don't know how they achieved it. @GlenOlliEsriUK @BenWalker
MonikaKwiatkowskaPL
Hi! I have the same issue but I work with Utility Network. I would like to achive workflow showed in this video created by Esri Australia: https://www.youtube.com/watch?v=KCG6koNhTmQ&t=1233s. In 20:40 you can see creating new set of features (residential connection) using some template. It is even said that this is a group template that will create a collection of features based  on predified rules established in ArcGIS Pro. And now I'm a bit confused beacuse there is still no support for group template in web feature layers: https://pro.arcgis.com/en/pro-app/latest/help/sharing/analyzer-warning-messages/24081-group-template...
Could someone help in this topic?
