AGOL/Portal save Popup settings to config file
609
01-15-2019 01:35 PM
Status: Open
SarahMyers
Much like Flex, saved the popup settings to config files, I'd like to see pop ups for Portal/AGOL be a saved file that auto loads with the service. by doing this you could set the popup settings in ONE file and apply it to every iteration and filtered version of the layer. For example, I have five different filtered versions of Primary UG Lines in my map. The data is customized for different zoom levels, symbology or key data that needs to be highlighted in a separate layer. I have to access each layer and customize the pop up for each, would be much easier to do it once and just reuse that file every time.
1 Comment
NickDierks1
Even if you had to manually upload the config file to each layer, this would still be faster than the current method of reproducing the entire workflow on every single instance. Great idea!
